After i have a text style in a drawing, can i set the current text style with lisp?
Currently I can only do it with the "-style" command.
Thanks
Thanks
Where STYLE is the desired style...You will still have to verify what style you want, unless you hardcode each style...Originally Posted by pmedina
Code:(setvar "textstyle" STYLE)
Thanks. The style will already exist in the drawing when i make it current. In my case it is first inserted into the dwg as a block, then the current text style is set.
