Thread: LandXML/Pipe Networks
    2006-04
    3
    Default LandXML/Pipe Networks
    When I create a pipe network in one drawing and then import it into another drawing with LandXML I get the following message: "Multiple Part Families with the correct geometry for Pipe [Pipe - (xx)] were found." for each pipe in each network. In the new drawing each pipe is set to the first pipe type in the part list which is different than the one in the pipe network in the original drawing. Both drawings were created with the same drawing template and parts list.
    What is causing this and how can I fix it?
    2007-08
    Brisbane, Australia
    42
    Default Re: LandXML/Pipe Networks
    Is it an option for you to use the Data shorcuts?
  1. Replies: 0
    Last Post: 2014-05-06, 09:11 PM
  2. 2013: Merging Pipe Networks
    By tim_newsome in forum AutoCAD Civil 3D - Pipes
    Last Post: 2012-11-02, 04:40 AM
  3. As-built pipe networks
    By kspear in forum AutoCAD Civil 3D - Pipes
    Last Post: 2011-08-30, 02:16 PM
  4. Civil 3D - PIPE NETWORKS
    By wag24 in forum AutoCAD Civil 3D - General
    Last Post: 2008-09-22, 01:04 PM
  5. Missing Pipe labels; Import Landxml File from Hydraflow
    By clarkl in forum AutoCAD Civil 3D - Pipes
    Last Post: 2008-04-29, 05:35 PM
