Thread: Construction lines tool?
    2006-10
    Cape Town
    94
    Default Construction lines tool?
    Probably an item for the wishlist but maybe there is a way that I do not know about. I would like to be able to use construction lines which extends indefinitely in a workplane, making them easy to place and to delete. In ADT I had a custom setting allowing me to press "vertical arrow" for a vertical construction line and "horizontal arrow" for a horizontal construction line which ensured that lines were always drawn quickly (one click) and accurately. Picking existing lines is great but when drawing, trimming a whole lot of construction lines is also often easier than selecting every endpoint. Being able to bisect angles with construction lines would also help. Any existing tool?
    2002-02
    St. Louis, MO
    4,695
    Default Re: Construction lines tool?
    Quote Originally Posted by rudolfesterhuyse
    Reference planes, Reference Lines and dimensions.
    To bisect an angle - place an angular dimension between the three objects. The hit the EQ on the dimension. done.
    In Revit, all planes are infinite (all surfaces of walls, reference planes in families, etc.) - so I'm not really sure what your after.
    2006-10
    Cape Town
    94
    Thanks, I appreciate the feedback and what you suggested sounds great. I expected I may have just been missing something. That is why I posted it here and not in the wishlist forum. Thanks.
  1. Construction Limit Lines
    By Arkman in forum Revit Architecture - General
    Last Post: 2023-01-12, 12:48 PM
  2. construction lines
    By ray salmon in forum Revit Architecture - General
    Last Post: 2009-03-05, 07:54 PM
  3. Construction Lines
    By the_cad_monkey in forum Revit MEP - Families
    Last Post: 2008-07-24, 08:15 PM
  4. Defpoint Lines / Construction Lines / No Plot lines
    By ykang in forum Revit Architecture - General
    Last Post: 2006-11-14, 10:30 PM
  5. Construction Lines Tip
    By H-Angus in forum ACA General
    Last Post: 2005-11-11, 04:59 PM
