Anyone know why I can't get 2007 to plot graduated solid hatches? the same hatches plot fine in 2005, I have tried the help which suggested fill and fill style but neither solves the problem. Any help much appreciated!
unfortunately that hasn't helped, all other solid hatches on the same layer plot.
HiOriginally Posted by dwgs
Could you please post an example drawing file that exhibits the behaviour you have described... we can then take a look at the issue / problem first-hand.
Have a good one, Mike
Here we are, the strange thing is the hatch plots fine with AutoCAD 2004 and 2005 and 2006 but simply ignores the hatch in 2007
Thanks, I will take a look later today...
Just in case, could you please also upload the Plot Style Table ( .CTB or .STB ) you are using on the DWG file testplot.dwg
here is the ctb file
It plotted out OK here, both on our 1050C and K/M Biz-hub. Printer driver problems, perhaps? What make/model printer?
HiOriginally Posted by timcreary
I get the same results as Tim ie Plot is ok!
I am able to successfully Plot DWG file testplot.dwg ( using Aqualuce_Clear_Print.ctb ), "Graduated Solid Hatches" assigned to table-lamp, output without a problem.
we use an HP1050C and HP800 and use the same drivers for AutoCAD 2007, 2006, 2005 and 2004.
Its only 2007 that gives this problem.
what did you mean by "Graduated Solid Hatches" assigned to table-lamp, Mike?
