I can't seem to be able to tag the membrane layers by material. Should I try harder or it is just not possible? Thanks.
I've been avoiding keynoting as I do not understand the word, but I guess I'll have take a look. Thanks.
The help file actually walks you through keynoting and it's capabilities pretty well, so check that out. I'm sure you'll find it useful.
Josh
Yeah - i know where you're coming from - it took me ages to get the ideaOriginally Posted by radu.grosu
(i come from a structural background and had never heard of keynoting) but
once you get the idea you'd never go back.
Keynoting is basically a system of keeping a database of all your notes that
you can automatically apply to objects. You can add whatever notes of your own to the existing keynotes file OR make your own up entirely, and keep adding to it as you need.
The beauty is that once you keynote an object within a project, you can quickly and easily "note" it again in any view with 100% consistency as it is contained within the objects properties.
Anyway - i don't know if my explanation is 100% accurate - but i hope it gives you a bit more of an idea!!
Adam
i dont know that you would be able to tag it because it does not have a thickness and does not show up. so far from what i can see is that the membrane layer is only to use for scheduling.
Justin
Thanks for the explanation Adam. Sounds good. Justin has a point, membrane have no thickness but to be honest, I expected them to show up as a line, that I could tag, change appearance of it, etc.. So, what do I have to do to show my membrane layers in section, use detail lines?
that is what i do. since the membranes have to lap over other and onto flashing etc. it is not really beneficial to have it part of the wall anyways. you would spend just as much time hidding lines then it would take you to draft them in.
justin
Justin is right, with no thickness the keynote by material isn't going to help. We decided to do user keynotes. User keynotes let you put in a keynote that isn't attached to anything, and just pick with keynote you want there. Working this way at least ensures that the note numbers and legends or the text is kept standardized across our set. Not a perfect solution, but better than dumb text.Originally Posted by jmarchiel-barch
DJF
We place membrane layers as Substrate with a thickness of 1/8" or .0006" depending on the thickness of the layer we want. You can tag those. The .0006 vapor barrier is hard but it will tag
