Thread: Better to have individual drawings?
    100 Club red2002yzfr1's Avatar
    2002-04
    Allentown PA
    141
    Default RE: How are companies using the Sheet Set Manager ?
    Correct me if I am wrong, but when using the SSM, does it work better if you have individual drawings. I currently have 4 rather large buildings and the way we handle our dwg's is we have one master dwg for each building.(downside to this is all of our computer are top end). We put all of our disiplines into one dwg, then we use our layout tabs as the "sheets" which are numbered to a disipline. I use Publish to handle our printing duties, loading different sheet list depending on the disipline. I tried to use the SSM, but the problem I had was I was having to create the same dwg for a different sheet in the SSM.
    2001-12
    St. Louis
    5,408
    Question Re: Better to have individual drawings?
    I'm not sure I understand your question?
    You can import as many layouts from one drawing to be listed as a sheet in the sheet set.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2002-04
    Allentown PA
    141
    Default Re: Better to have individual drawings?
    Well, I tried with a little help from my vendor, to set up sheet sets and the conclusion that was given to me was since I use one master dwg for a whole building, setting up a sheet set would require me to make multiple copies of the same dwg.
    Administrator richard.binning's Avatar
    2015-12
    In the foothills of the appalachians
    2,261
    Talking Re: Better to have individual drawings?
    Find out the best way to use these by visiting Shaan Hurleys Blog: "Between the Lines". Check out his post about the "Best Practices Series" of whitepapers on the .
    2015-12
    2,261
    Quote Originally Posted by joe.szabo
    No, just xref in the master dwg to each plottable sheet drawing.
    RLB
  1. Individual Residences
    By Admiral McAwesome in forum Revit MEP - General
    Last Post: 2011-07-22, 01:50 PM
  2. Trying to Publish Several Individual Drawings to Single PDF's in one go.
    By douglas.courtney in forum AutoCAD Plotting
    Last Post: 2010-04-21, 01:50 PM
  3. Search text within drawings, without actually opening drawings
    By Animesh Kundu in forum AutoCAD General
    Last Post: 2008-02-29, 05:34 PM
  4. Each Alignment in individual drawings or...
    By Civil-Tech001 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2008-01-07, 11:58 PM
  5. Enterprise vs Individual
    By dhurtubise in forum AutoCAD CUI Menus
    Last Post: 2005-08-27, 01:42 AM
