Hello
Im not sure if this is the right place for this post BUT here goes:
I am having trouble with the computers on my office's network taking an impossibly long time opening the file browser upon any command that requires this...such as Open or Save as. After much research and tinkering I have discovered that there is some background service that starts up with windows that is causing the trouble - I know this because I dont have the problem when I choose a "Diagnostic Startup" from the System Configuration Utility (run msconfig). I tried to pinpoint the precise application which was causing the problem but there are far too many to weed out the culprit. I know that I had success once when I told Norton not to scan my Autocad related files (eg dwg bak etc) but the problem persisted or changed into something else. I have since uninstalled Norton and have tried AVG. I also tried to disable anything I thought as suspicious but it has not worked.
So what I am looking for specifically is the program to disable at startup so that Autocad may run in a nrmal manner.
thanks for your help in advance.
G.
