Hello:
We're having problems printing in Revit to our Oce TDS600 plotter, using the Oce Windows Raster Driver. The driver is cutting off an inch off the right edge of our 30x42 sheets.
The sheet size is set to 30x42, but the plots are coming out 30x41....
We also plot ADT drawings to the Oce plotter w/o problems, so the issue is with Revit/Oce driver, not the plotter hardware. Our plotter uses older firmware, so we can't use the newer Oce Windows Printer Driver.
Has anyone else experienced this problem, and if so, how did you resolve the issue?
