I'd like to see a template for revision tables, much like table templates in the autocad 2005 products.
I'll second the vote for rev table template,
I agree. Also you should be able to set the template column widths by using dims,.like the parts lists.
I third the vote for the Rev table template. Please fix this. This is a major problem.Originally Posted by rosterreicher
I'd like this too. Also fix the margins of the Revision Tables, I find that if my text is left or right justified the lines for the columns and the text often touch.
The Parts List have a nice why to format them the Revision Tables should too.
There should be a GUI for creating custom tables, I know you can create them using VBA but this can be some what time consuming. And they should at least have the same functionality as the new tables do in AutoCAD 2006.
Benjamin
For those who didn't get the word, the top 10 Inventor wishes were submitted to Buzz Cross at the annual AUGI meeting at AU 2005. The revision table wish was #6. Check out the others on http://www.blaugi.com
