Results 1 to 8 of 8
Thread: Dummy Dimension family
    2001-12
    1,714
    Default Dummy Dimension family
    I seem to remember some discussion a while back about a dummy dimension, for use when you want the look of a dimension, but with just some text. For example, in AutoCAD I would often have a dimension that showed the extension line and a tick on one side, and no extension line and an arrow on the other. This was good for showing an open ended dimension with text that said Existing or New.
    Any suggestions?
    Gordon
    All AUGI, all the time gwnelson's Avatar
    2003-04
    Westchester County, NY, USA
    612
    Default Re: Dummy Dimension family
    I just duplicated a damily & chqanged the text size to really tiny (1/256" is the smallest) & then you can just add text to the dim line. It would be nice to override text like that other program.
    2001-12
    1,714
    Quote Originally Posted by gwnelson
    We have just been dropping a piece of text with an opaque background over the dimension, but that feels like early 90s era AutoCAD, not early 21st Century Revit!
    Hopefully there is either a better answer, or some improvements in 10.
    Best,
    Gordon
    I could stop if I wanted to Rhythmick's Avatar
    2004-03
    Colorado
    323
    There was THIS thread!
    Mike Lenz
    Genuine Homes Corp
    "Gone Fishing"
    2004-01
    Overland Park, KS
    8
    I would suggest setting up a dimension style with a blank font (ttf). Place your dimension as you normally would. It will place the extensions and ticks but no font. All you'll need to do is add your own text. We tried the opaque text method mentioned above but found this solution much better. I found a blank font via google. If you have no luck finding one I'd be more than happy to pass mine along.
    Regards,
    Steve
    Steven W Cox, RA
    IT/CAD Manager
    Hollis + Miller Architects
    100 Club cstanley's Avatar
    2005-05
    Dallas, TX
    168
    that sounds like a solid answer. may i see an example of your blank font?
    2001-12
    1,714
    Quote Originally Posted by cstanley
    Solid WORK AROUND sure, but a solid ANSWER is the ability to override the dim value. And while they are at it, the ability to add text below the dim line ala AutoCAD "\X" would be nice.
    Gordon
    100 Club s.messing's Avatar
    2006-08
    Cambridge, MA
    174
    Quote Originally Posted by Steve Cox
    Regards,
    Steve
    Excellent. First time I have seen this answer. We use the opaque backed regular text trick, but I'd be interested to see this blank font thing in action. It seems to make more sense.
    Thanks for the suggestion.
    Stephen
    PS: I would certainly not complain if you do share the text with us.
  1. Where is the dummy forum?
    By jmdraft0 in forum New Forum Users (Non technical)
    Last Post: 2012-02-28, 05:59 PM
  2. dummy people pass
    By batproj in forum Français - 3ds Max / Maya
    Last Post: 2010-11-22, 01:33 PM
  3. Standard details - best in dummy project or template?
    By fernandez in forum Revit Architecture - General
    Last Post: 2009-04-23, 05:06 PM
  4. DCL's for dummy
    By gfreddog in forum AutoLISP
    Last Post: 2009-02-06, 04:59 PM
  5. How do I make a dummy schedule?
    By whatisrice in forum Revit - Platform
    Last Post: 2008-03-25, 03:47 PM
