Thread: Advantage of using Rotate & Mirror parameters with a DB, compared to...
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Question Advantage of using Rotate & Mirror parameters with a DB, compared to...
    what is the advantage of using the rotate & mirror paramaters with a DB / or regular block instead of the default CAD rotate / mirror? i can see in a complex block, or for rotating / mirroring a specific part of a block, but what about simple blocks (say - a toilet & grabbars with no vis states and what not)?
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Advantage of using Rotate & Mirror parameters with a DB, compared to...
    Quote Originally Posted by Chad_C
    single click results vs. finding command and then finding/ selecting basepoints. In Other Words: SPEED
    S&D DB Sharing Forum
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Speed is the main thing. Plus keeping blocks in the positive X axis is always good practise too. Ever go and see how many blocks have positive X Y and / or Z axis in a regular drawing using regular blocks? Not pretty.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    2006-04
    1,129
    Quote Originally Posted by max.sabre
    i like this answer. ive tried to rescale all the blocks at once, when half were -X it was ugly.
    thanks
  1. 2014: Is there ANY way at all to get legend components to mirror or rotate??
    Last Post: 2013-10-03, 02:25 PM
  2. linking rotate parameters?
    By revitrookie in forum Dynamic Blocks - Technical
    Last Post: 2009-04-30, 03:48 PM
  3. Is it possible to Chain two Rotate Parameters ?
    By derek.96018 in forum Dynamic Blocks - Technical
    Last Post: 2009-04-29, 01:14 PM
  4. Want Equivalent to Rotate's Spacebar for Mirror
    By Andre Baros in forum Revit Architecture - Wish List
    Last Post: 2005-04-12, 07:49 AM
  5. Mirror, Mirror (revisited)
    By BillyGrey in forum Revit Architecture - General
    Last Post: 2004-06-04, 01:03 AM
