Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: AutoCAD 2006 unable to open DWG file created in same version - Drawing file not valid
  1. #11
    I could stop if I wanted to andy.manninen's Avatar
    2015-10
    @ _ork
    304
    Default Re: AutoCAD 2006 unable to open DWG file created in same version - Drawing file not valid
    Quote Originally Posted by gary.gentry
    Awesome! I didn't even think of that! The dwg probably was toast, but the .bak file was there. Thanks for the reminder. She says she's gonna buy me a drink for my troubles. Thanks a bunch
    (Wipes brow) Yippee for BAK files!
    :Cheers:
  2. #12
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    I have tried audit and recover. I don't know what RegApps is. Can you briefly explain? I can't open the drawing at all so how can I purge the Dwg? Thanks for the help.
    Regapps are things that third-party software tend to put into a dwg file. They tend to muck up the drawing and increase the file size unreasably. For some reason, the PURGE dialog box doesn't get rid of the little buggers, so you have to use the old typed command by typing '-PURGE' at the command prompt.
    Meanwhile, a block is just like any other dwg. Sometimes, depending on the initial problem, a drawing can be intserted into a new, blank drawing, then worked on.
    Additionally, a bak file is created each time you save a dwg. Unfortunately, if you go a long time between saves, the bak file won't have all the changes.
  3. #13
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    I am a student and it is not my dwg. I doubt they will let me. I'll check.
    If its not your drawing, Is there a chance that this file is on a network and was opened by a different user using AutoCAD 2007? The error message is usually a higher version format being opened by a lower AutoCAD version...Just a thought.
  4. #14
    13,656
    Hi
    You may wish to browse the information found in the following thread ( remember to take note of all links found within )...
    Open a corrupt drawing file
    Have a good one, Mike
  5. #15
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Quote Originally Posted by arshiel88
    More frequently, that message simply means you have a corrupted file, and it is now useless.
    Autocad is pretty bad about corrupting files, especially with the newer verticals like Civil-3D. Vanilla isn't so bad, but the newer verticals can be pretty terrible. It's a severe problem with the software that we just seem to have to live with for the time being, and hope Autodesk fixes...
  6. #16
    100 Club smooth shoes's Avatar
    2006-11
    Backwoods
    126
    Thanks all of you for your input. The .bak file was there and I did get it workin.. with y'alls help of course. Thanks again
  1. AutoCAD 2008 unable to open a drawing file that crashed
    By gregoran in forum AutoCAD General
    Last Post: 2007-06-28, 06:17 PM
  2. Replies: 10
    Last Post: 2007-02-07, 07:43 PM
  3. Replies: 6
    Last Post: 2006-10-13, 01:00 PM
  4. Unable to Open a drawing file
    By mwittens83539 in forum AutoCAD General
    Last Post: 2005-07-07, 08:02 AM
