Thread: Only Attach type Xref Attachment?
    100 Club KevinBarnett's Avatar
    2001-10
    Pretoria, South Africa
    119
    Unhappy Only Attach type Xref Attachment?
    Hi,
    Review of Sheet Set Development:
    Step 1
    Make Sheet Set Structure (subsets)
    Step 2
    Configure subset templates (titleblocks)
    Step 3
    Add Resource Drawings
    Step 4
    If Resource Drawings do not include Views - add Views to them
    Step 5
    Start a new Sheet
    Step 6
    Place Resource Drawing View in Sheet
    Stop the bus!!! When you add a resouce drawing view, the sheet set manager xrefs the resource drawing add a new layer and sets vpfrz layer properties. If you add another resource drawing - you get another viewport and the viewports are set to frz so that resource drawings do not merge in viewports. If your Xref method is Attach type Attachment then sheet set manager will work for you. What about drawing offices that prefer to use Overlay attachment? Must we change to Atrtach type before we can utilise the sheet set manager?
    Kevin.
    2001-12
    St. Louis
    5,407
    Cool Re: Only Attach type Xref Attachment?
    Quote Originally Posted by kevin.barnett
    Hi,
    Step 1
    Step 2
    Step 3
    Step 4
    Step 5
    Start a new Sheet
    Step 6
    Kevin.
    unfortunately, that is the only option they've made available so far.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Multileader Right-Side Text Attachment Type
    By baustin in forum Dot Net API
    Last Post: 2011-11-23, 05:52 AM
  2. xref attachment
    By mdsalman2003 in forum AutoLISP
    Last Post: 2010-07-09, 03:35 PM
  3. Change xref from attachment to overlay
    By Tineli in forum AutoCAD General
    Last Post: 2010-07-02, 05:30 AM
  4. xref type OVERLAY to ATTACHMENT
    By Yancka in forum AutoCAD General
    Last Post: 2008-06-04, 04:15 PM
  5. Viewports and Xref attachment or overlay
    By csdraft in forum AutoCAD General
    Last Post: 2004-12-17, 04:22 AM
