Hello,
It seems that when I place a Bearing wall meeting with a Non-bearing wall, the line work does not cleanup. There is always a line separating the two. I have to change the Bearing walls to Non-bearing to eliminate the line that appears on all views. I have tried painting the walls with the same material and applying the same wall finish to both, but no luck getting rid of the division line.
Is there any way of using both types of wall without having a line dividing the two ?
Thanks in advance.
