Results 1 to 10 of 12
Thread: Globally convert text to mtext
    2016-01
    43
    Default Globally convert text to mtext
    Does anyone know of a routine that will globally convert text to mtext?
    There are well over a hundred strings of text in this one particular drawing that need to be converted into individual mtext entities. I'd rather not have to select each text string to convert.
    Any help would be much appreciated.
    Thanks
    Steve
    150700
    3,434
    Default Re: Globally convert text to mtext
    Quote Originally Posted by Stephen.Walz
    Thanks
    Steve
    If you scroll down, you will see a similar threads tool; there are few threads listed there that might help you.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,463
    According to R.K.McSwain in this thread, convert all text to mtext, there is a Third Party Solution.
    2004-07
    Detroit Michigan
    2,508
    What about a routine that converts back and forth?
    Wouldn't that be worth more?
    Earth
    9,754
    Quote Originally Posted by Robert.Hall
    MTEXT to TEXT can be done using ._EXPLODE
    R.K. McSwain | CAD Panacea |
    I could stop if I wanted to kpblc2000's Avatar
    2006-09
    212
    For transformation text in mtext it is possible to take advantage Exress Tools - txt2mtxt. It is possible also variant of the decision to make...
    Use AUTOCAD / ADT / AA 2006 / 2008 / 2010
    All i say is only my opinion
    I'm watching you! Your
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by rkmcswain
    I hear you 100% however I still think a routine would be more appropriate.
    The routine could be set to automatically grab all text objects.
    2002-01
    jUSt Here (a lot)
    8,463
    You may want to adjust that a bit to MTEXT objects.
    150700
    3,434
    I would think that would be easy enough to create - but it's just as easy to do a qselect of all mtext and explode 'em that way too ~shrug~
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    . . . and to reverse ? ?
    that is the sticky task. . .
    : ) Happy Computing !
    kennet
  1. Convert Field to Text within Block Globally
    By OCD in forum AutoCAD General
    Last Post: 2018-07-29, 02:35 AM
  2. Convert Mtext to Text
    By MikeJarosz in forum VBA/COM Interop
    Last Post: 2007-08-30, 09:13 PM
  3. convert all text to mtext
    By c_rado in forum AutoCAD General
    Last Post: 2006-12-03, 11:15 PM
  4. AutoCAD LT 2006 - Convert Text to MText?
    By flansburg in forum AutoCAD LT - General
    Last Post: 2006-03-07, 07:59 AM
  5. Vl commands to convert text to Mtext
    By ccowgill in forum AutoLISP
    Last Post: 2006-03-03, 06:54 PM
