I have a mock up file of an HVAC system, with an Air Handler on the "roof" and a riser coming down, to feed teh main duct loop in the first floor ceiling.
I xref in the rooftop unit, and have no problem connecting up my duct runs. What Im having trouble with, is cutting the xref away in plan. I need to have teh riser there, but not see the ahu that is technically on the roof
(im working i metric) The cut plane lower is at 1500. The lower at 0, and the top at 4100 (the highest point of my ducts is 4090). The AHU is at an elevation of 4200.
But - I still see the unit. since its out of my display range, I should not see it...
THEN - for my property set ==> Display options, I checked teh box: Section AEC objectsby display range defined in Display Configuration.
This works for my iso views, but in plan, still get my unit. Anyone know how to accomplish what Im trying to do (without using project navigator!)
