I have never posted a reply before but I happend to be playing with this same situation where I wanted to keep the existing path and add another one to it so this is what I came up with. It is very much like the one you wrote but this keeps the existing path and will add another path to the toolpalette paths
Sub ToolPalettePath()
'This example changes the tool palette path
Dim objPref As AcadPreferences
Dim strSupport As String
Dim strPath As String
Set objPref = Application.preferences
strSupport = objPref.Files.ToolPalettePath
strSupport = "<COPY AND PASTE THE EXISTING PATH HERE>" _
& ";" & "<PUT THE PATH YOU WANT TO ADD HERE>"
' You can add more paths using a underscore to continue to the next line
objPref.Files.ToolPalettePath = strSupport
End Sub
