Results 1 to 6 of 6
Thread: When using the Shortcut menu - Unknown command "AI_DIM_TEXTHOME"
    2005-08
    Salt Lake City, UT
    7
    Default When using the Shortcut menu - Unknown command "AI_DIM_TEXTHOME"
    I'm having problems with at least one command in the shortcut menu for dimensions. I'm trying to put a piece of dimension text back to the 'home' position using the shortcut menu and I get the following error:
    Using the align text under the Dimension pulldown works just fine but not the right click shortcut menu. This is occurring on multiple machines in my office.
    This is one example I've personally seen but some people are telling me it occurs with other commands.
    Any ideas? Thanks.
    Shane
    Member digiwurx's Avatar
    2005-03
    Greenbush, Maine
    30
    Default Re: When using the Shortcut menu - Unknown command "AI_DIM_TEXTHOME"
    It sounds similar to an issue we had. It was the acad.mnl file that was not loading. go to your command line and enter (LOAD "ACAD.MNL") . See if this takes care of your issue. Also make sure that you have Service Pack 1 installed. It may not have anything to do with this issue, but it is always a good practice that fixes a lot of "bugs". Hope this helps.
    Rob
    2005-08
    Salt Lake City, UT
    7
    Service Pack 1 is installed and loading the acad.mnl did not help. In the shortcut menu under the "Dim Text Position" above dim line, centered & home text return "Unknown Command" while the other options work fine.
    Shane
    13,657
    Hi
    Does _ai_dim_texthome work correctly if inputted via the AutoCAD Command Line ?
    Have you gone into the Customise User Interface and looked at Dim Text position under Dimension Objects Menu, found under Shortcut Menus ?
    If no, take a look.
    If yes, does everything look to be setup correctly ?
    Have a good one, Mike
    2005-08
    Salt Lake City, UT
    7
    Quote Originally Posted by Mike.Perry
    Hi
    If no, take a look.
    The commands _ai_dim_textabove, _ai_dim_textcenter & _ai_dim_texthome do not work at the command line. The only thing that is a little odd in the CUI are the commands themselves, the move text commands have _aidimmovetext_# while these three commands have the underscore. I did try all deviations and still nothing.
    Shane
    13,657
    Hi
    Quote Originally Posted by shanem
    Check if acad2007doc.lsp is being loaded successfully.
    Move text alone should have Macro ^C^C_aidimtextmove _2 associated with it.
    Move with leader should have Macro ^C^C_aidimtextmove _1 associated with it.
    Move with dim line should have Macro ^C^C_aidimtextmove _0 associated with it.
  1. 2015: Command: _RBCS_prjpref Unknown command "RBCS_PRJPREF".
    By mankie1 in forum AutoCAD Structural Detailing
    Last Post: 2014-11-14, 03:32 PM
  2. AUTOCAD 2013 Error: _sheetset unknown command "sheet set"
    By omorah in forum AutoCAD Customization
    Last Post: 2012-06-18, 09:25 PM
  3. Double "Unknown command" After Routine
    By stusic in forum AutoLISP
    Last Post: 2008-05-05, 08:39 PM
  4. AutoCAD Mechanical 2007 - Unknown command "CUI"
    By svanderputten in forum AutoCAD Mechanical - General
    Last Post: 2007-01-16, 05:01 AM
  5. Replies: 4
    Last Post: 2006-02-03, 07:34 PM
