Thread: Export a TIFF from AutoCAD with the background transparent
    100 Club gisdude's Avatar
    2005-10
    104
    Default Export a TIFF from AutoCAD with the background transparent
    hi all.
    i am trying to use a drawing as a figure in an excel spreadsheet. this figure will prolly take up half of a standard letter size.
    i want to export the dwg as a tif(which I can do) but I want the background to be transparent(no color, which i can't seem to do). i always end up with a black(or white) background depending on which background I choose.
    is this possible? is there a workflow for this? i do have some photoshop skills, but it seems like this would be straightforward to do in Autocad.
    TIA
    Turlock, CA
    6,379
    Default Re: Export a TIFF from AutoCAD with the background transparent
    Raster images map a color for every pixel in the image, so there's no such thing as truely transparent. In acad if an image's color depth is 2, or bitonal, (bk & w), then it can 'turn off' the white and only display the black, by replacing the white with whatever else is on the screen. Again, that only works with bitonal images, even though you can select 'transparent' on any IMAGE. Going the other way, exporting out of acad, all you're going to get is a tif. Some other raster editing programs can add a layer of information that can create a mask by mapping a color you choose to be the 'transparent' color. Sort of like the way movie makers use the "green screen".
    C:> ED WORKING....
    13,656
    Question Re: Export a TIFF from AutoCAD with the background transparent
    Hi
    Instead of outputting to TIFF have you looked into using WMF instead ?
    Have a good one, Mike
    2005-08
    Albania
    423
    Quote Originally Posted by rlong.96213
    hi all.
    TIA
    Is there a choice the "saveimg" command.?
  1. Export drawing with a Transparent Background?
    By Lew in forum AutoCAD General
    Last Post: 2017-03-21, 03:48 AM
  2. tiff won't print in background of PDF
    By Maverick91 in forum AutoCAD Civil 3D - General
    Last Post: 2012-02-21, 09:05 PM
  3. Replies: 1
    Last Post: 2007-05-31, 12:52 PM
  4. Some TIFF's not showing as transparent in PDF
    By Maverick91 in forum AutoCAD Plotting
    Last Post: 2006-07-04, 01:05 PM
  5. Filled region with transparent background not transparent
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2005-09-12, 09:24 PM
