tedg
Yup, if set your "ltscale" to whatever you want, and "psltscale" to 0 it will appear the same in paperspace and model space.
But if you have different scaled viewports in the same sheet, it can cause a problem.
The psltscale set to 1 makes all the ltsclales appear the same in different scaled viewports. Your ltscale would need to be set at something like 1 (or .5 if you like the appearance of a half scale line type). Obviously this causes the problem of going into model space and having the ltscale set too low and you can't see it.
