Thread: Custom Symbols not displaying from customised font file
    2006-08
    Fayetteville, AR
    92
    Red face Custom Symbols not displaying from customised font file
    So here is the story. We use a font called Handlet.SHX, for some reason it's character mapping didn't include symbols. A former employee added the charcters we needed, the degree symbol and the plus minus symbol and he says he got it to work. All this happen before me. We are currently running AutoCAD Lt 2007, he fixed the problem with a full version 2002. The font for whatever reason is not showing the symbols in either the full version of 2002 or the LT 2007. When I get on his old computer I can view the shx file through a program he had and the symbols are there, AutoCAD leaves a blank for them. Actually if I dimension an angle w/ Handlet there is a space after the numbers and if you switch the font the degree sign appears. Any help is very much apperciated!!!!!
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,018
    Default Re: Custom Symbols not displaying from customised font file
    Make sure the modified SHX file is in a folder that is listed in the Support File Search Path. You will have to make sure that that folder is listed before the folder that contains the unmodified file.
    Jeff Paulsen
    2006-08
    Fayetteville, AR
    92
    All the folder stuff is correct.
  1. CUI file customised in 2008 loaded in 2007
    By benmay in forum AutoCAD CUI Menus
    Last Post: 2007-05-18, 02:24 AM
  2. Text not displaying / using correct font file
    By michellewatkins in forum AutoCAD LT - General
    Last Post: 2006-11-21, 07:42 PM
  3. Swap old custom font file for new font file
    By dgalloway in forum AutoCAD Customization
    Last Post: 2006-02-02, 03:09 PM
  4. Adding custom characters to font file
    By m_r_meza in forum AutoCAD Customization
    Last Post: 2005-07-08, 11:42 PM
