hi friends i am very new to Auto Lisp how can i invoke Auto lisp command, i type auto lisp in command prompt, but there is an error comes its an invalid command, i have a some of lisp tutorials,
Hope a reply ASAP
Hope a reply ASAP
Please note I have moved this to the AutoLISP forum from the ADT tips/tricks forum as I feel this is a more appropriate place for it to receive a better response.
If I understand you correctly (and this is just a guess), you are trying to get to the VL interface. Just type VLIDE at the command prompt. Let us know if I have made a bad guess.Originally Posted by gurudas.ku
Which version of AutoCAD are you using?Originally Posted by gurudas.ku
Hi gurudas.ku,
For the best solution you should post here your code,without seeing your code,I can not help you.
Here as a sample code
Now you do,block that code with your cursor then hit right button,hit copy.Code:(defun c:test (/ p1 p2 p3 p4) (setq p1 '(0 0 0)) (setq p2 '(10 0 0)) (setq p3 '(10 5 0)) (setq p4 '(0 5 0)) (command "_pline" p1 p2 p3 p4 "c" "") (princ) ) ; defun
open your cad,at command prompt type "vlide",find icon "new file",hit them and click at upper left corner,then hit right button your mouse,hit paste.
save as your folder and give them name with extention lsp,find again icon "load active edit window",hit them.
move session to acad,at command prompt type "test",now watching it,and what happended in drawing area.
