Thread: Why can't i filter an area schedule by Area Type?
    2006-01
    4,516
    Default Why can't i filter an area schedule by Area Type?
    I created an Egress Drawing that "kind of" updates automatically as the SF of the areas change...
    Its necessary for the retail work im doing right now. 6 people in the model, the demise walls keep moving, and for various reasons, i had to use an Area plan instead of a Floor plan with rooms.
    Anyway, i made a simple Area schedule.
    Now i want to filter out the "Building Common Areas" so im only left with the "stores," but although it is a field in my schedule, i am not able to select it under Filter.
    Any idea why?
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Default Re: Why can't i filter an area schedule by Area Type?
    I don't know the reason that some parameters are unavailable in the filter command, but you can work around by using a comments or description field, manually add a key by which to filter, and then apply the filter.
    2005-07
    Somewhere in the BIM world
    3,792
    That definitely sounds like a wishlist item.
  1. 2014: Change the area type referenced by a schedule?
    Last Post: 2023-07-28, 03:16 PM
  2. Area Schedule Filter and Wild Cards
    By phyllisr in forum Revit Architecture - General
    Last Post: 2018-12-19, 08:57 PM
  3. Ability to address the Property Line Area Parameter in a Gross Building Area Schedule
    Last Post: 2013-02-21, 01:11 PM
  4. Area Schedule - Gross Footprint Area & Built Area
    By kurk in forum Revit Architecture - General
    Last Post: 2006-06-03, 12:43 PM
  5. Area schedule - filter by area type
    By Tom Dorner in forum Revit Architecture - General
    Last Post: 2004-02-24, 12:16 AM
