Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Multiple Visibility States - Is there a better Way?
    2003-05
    335
    Default Multiple Visibility States - Is there a better Way?
    Guys,
    Please check out what am I doing with my vis states to see if I have gone way overboard or if this is the way you guys do it too.
    Is there a better way? Am I doing something wrong? Is 2007 any better?
    Will
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default Re: Multiple Visibility States - Is there a better Way?
    Quote Originally Posted by whdjr
    Guys,
    Will
    nice block!
    how did you get the lookups to work with visiblity states? i would have never thought about doing that.
    2003-05
    335
    Lookup 1 Lookup2 Lookup3
    1 mullion 45 degrees 1 mullion
    2 mullion 60 degrees 2 mullion
    3 mullion 90 degrees 3 mullion
    Vis state would be:
    1m-45-1m
    1m-45-2m
    1m-45-3m
    1m-60-1m
    1m-60-2m
    1m-60-3m
    1m-90-1m
    1m-90-2m
    1m-60-3m
    2m-45-1m
    2m-45-2m....etc.
    It continues all the way down. Then you have to show and hide each lookup during its coresponding vis state. Very time consuming.
    Is this clear?
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by Chad_C
    nice block!
    Chad, check out the FIXTURE here, i believe i used vis states in the lookup....
    S&D DB Sharing Forum
    2001-12
    Rochester, MN
    2,561
    Vis state would be:
    1m-45-1m
    1m-45-2m
    1m-45-3m
    1m-60-1m
    1m-60-2m
    1m-60-3m
    1m-90-1m
    1m-90-2m
    1m-60-3m
    2m-45-1m
    2m-45-2m....etc.
    Is this clear?
    time consuming is right! i've done some like that, but not as complicated. have you done anything with referencing other lookups in the lookup? i haven't been able to wrap my mind around that one yet.
    if you need a block that does that, then i don't see another option. i haven't upped to 2007 yet myself, so i don't know. i will soon tho.
    2006-04
    1,129
    Quote Originally Posted by Chris.N
    i hadnt seen that one. nice stuff there too =)
    2003-05
    335
    time consuming is right! i've done some like that, but not as complicated. have you done anything with referencing other lookups in the lookup? i haven't been able to wrap my mind around that one yet....
    No I haven't figured that one out yet. I tried to use the bolt in the AutoCad sample drawings to study but it's pretty illusive.
    2006-08
    Fayetteville, AR
    92
    OK what whjdr did with this dynamic block is what I was trying to do with the weld symbol. By the way I seen the one that comes with Autocad and it doesn't have any leader options (tail, field weld, all around weld) and that is what I'm trying to add. The quick explanation that was given on how he did what he did I don't understand. I'm using LT does that hinder some of my capabilities with DB?
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by tiffany.amorgan
    possibly.....
    2003-05
    335
    Ok, I'll try. If you'll notice the vis states are setup to show each scenario.
    The lookups allow for 0 or 1 mullion on the left side, 0 or 1 mullion on the right side, and insulated or non-insulated glass. Otherwise 0m or 1m, 0m or 1m, or IG or NIG.
    0m-0m-ig
    0m-0m-nig
    0m-1m-ig
    0m-1m-nig
    1m-0m-ig
    1m-0m-nig
    1m-1m-ig
    1m-1m-nig
    There are 8 possible combinations. You have to put 8 lookups at each lookup position and then either hide or show the lookups and the drawing data to produce the desired look.
    Simple right? Not really but that's the jist of it.
    Hope that helps,
  1. 2010: multiple visibility states
    By bstk in forum Dynamic Blocks - Technical
    Last Post: 2014-10-02, 01:53 PM
  2. Multiple visibility states (Not look-ups)
    By Kernal_CAD_Monkey in forum Dynamic Blocks - Technical
    Last Post: 2012-07-31, 03:52 PM
  3. multiple visibility states
    By bbapties in forum Dynamic Blocks - Technical
    Last Post: 2008-07-24, 06:45 PM
  4. Multiple Visibility States
    Last Post: 2007-10-02, 04:20 PM
  5. Multiple visibility states??
    By blaine.67000 in forum Dynamic Blocks - Technical
    Last Post: 2006-01-30, 03:59 PM
