Heres one thats simple (I'm sure most of you already know it).
Instead of typing PEDIT to edit a polyline, just double click it. The options will show on the command line as usual.
Cool, and for those who want to convert a line to a polyline, and are typing PEDIT, just type PE....
Works in what version?Originally Posted by dzatto
It works in Mechanicl 07 (I assume vanilla as well); I don't think I've modified my CUI to have this effect, I believe it to be OOTBOriginally Posted by rkmcswain
Ok, Works in 2007, but not 2006 (or earlier I suppose).Originally Posted by BrenBren
I can confirm this does not work for earlier version of AutoCAD. This must have something to do with the Double Click settings available in the CUI for 2007.Originally Posted by rkmcswain
2006 & 2007 ACAD require you to set "peditaccept" to 1 (I think) to make it work without asking if you want to make it a polyline every time.
Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
I was not referring to the "peditaccept" part of this working, only the "double-click" ability. But your statement is still true, with the exception of the "2006" part, since 2006 does not start the ._PEDIT command upon a double-click.Originally Posted by drafter29
Sorry guys, I forgot to state what version. I'm on ADT 2007. I guess it is a 2007 only thing.
And it was right there the whole time!
