Thread: Are there any compatibility issues if you run the same CUI file in 2006 and 2007?
    100 Club mcoffman's Avatar
    2005-08
    Porland, OR
    128
    Default Are there any compatibility issues if you run the same CUI file in 2006 and 2007?
    Are there any compatability issues between running the same .cui file between 2006 and 2007?
    Thanks,
    MC
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,854
    Default Re: Are there any compatibility issues if you run the same CUI file in 2006 and 2007?
    The cui will become read only to 2006.
    2005-08
    Porland, OR
    128
    If the need should arise, is it possible to do a "transfer" from the read-only '07 cui to an new '06 cui?
    2002-01
    jUSt Here (a lot)
    8,854
    I have not tried it. You can still use the same CUI for both versions. The '06 version just will not be allowed to modify it.
    Retired Forum Staff Rico's Avatar
    In the hospital cuz of my fever for more cowbell
    1,828
    Quote Originally Posted by Opie
    The big problem comes in that the 06 doesn't have some things that the 07 has. For example, the ability to modify double click actions. 06 does not have it. So when a CUI from 06 is transferred to 07, this entire feature (the ability to double click things and get CAD to do what you want) will not be there. Trust me. I know this one from experience.
    As for going from a 07 CUI to an 06 one .. I didn't think it was possible ... aren't CAD programs "non forward compatible"? That is, 06 can't read an 07 file ... so why would an 07 CUI file work in an 06 machine?
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
  1. More file compatibility issues
    By richardronan in forum AutoCAD General
    Last Post: 2009-10-07, 02:08 PM
  2. Looking for "white paper" discussing 2006-2007 compatibility issues
    By rdomke69 in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-08-03, 05:40 PM
  3. Replies: 8
    Last Post: 2007-01-16, 03:02 PM
  4. Copatability issues with ADT 2007 and 2006
    By blu2767 in forum ACA General
    Last Post: 2006-10-03, 05:45 PM
  5. AutoCAD 2007 compatibility DWG format with AutoCAD 2006
    By cskelton in forum AutoCAD General
    Last Post: 2006-05-24, 02:09 AM
