Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Assign Double Click action to dimensions
    All AUGI, all the time cadkiller's Avatar
    2003-09
    Bergenfield, NJ
    697
    Default Assign Double Click action to dimensions
    Group;
    I recently added a double click action for my dimensions. I now can double click my dimensions and the edit text command is enabled.
    1-Go to CUI double click actions and add a new one.
    2-Put dimension in the general name and advanced object name.
    3-Then drag the edit text command from the lower left hand corner to the new double click action.
    Turlock, CA
    6,447
    Default Re: Assign Double Click action to dimensions
    I have a vba solution if anyone doesn't have cui (pre 2006).
    C:> ED WORKING....
    LinkedIn
    2003-09
    Bergenfield, NJ
    697
    I would like to see it even though I already set mine up.
    I have a friend that is on 2004 that would be interested in your VBA solution.
    Turlock, CA
    6,447
    Add this to a class that is initialized "With Events". Load the class at startup. Set its Doc property to ThisDrawing.
    Public WithEvents Doc As AcadDocument
    Private Sub Doc_BeginDoubleClick(ByVal PickPoint As Variant)
        'If item being clicked on is a dimention,
        'then open the Mtext editor instead of the properties dialog.
        Dim s1 As AcadSelectionSet
        Dim oEnt As AcadEntity
        Set s1 = ThisDrawing.PickfirstSelectionSet
        If s1.Count > 0 Then
            For Each oEnt In s1
                Select Case oEnt.ObjectName
                    Case Is = "AcDbAlignedDimension"
                        ThisDrawing.SendCommand "ddedit "
                    Case Is = "AcDb2LineAngularDimension"
                    Case Is = "AcDb3PointAngularDimension"
                    Case Is = "AcDbDiametricDimension"
                    Case Is = "AcDbOrdinateDimension"
                    Case Is = "AcDbRadialDimension"
                    Case Is = "AcDbRotatedDimension"
                End Select
            Next oEnt
        Else
        End If
    End Sub
    C:> ED WORKING....
    LinkedIn
    Active Member jim.dozorec's Avatar
    2001-11
    Edmonton, Alberta, Canada
    62
    Hi, All
    Maybe I'm a little daft, but I can't find out what CUI means. Can someone enlighten me?
    Thanks, Jim
    2003-09
    Bergenfield, NJ
    697
    Customize User Interface
    Type CUI at the command prompt and see if your version has one.
    2001-11
    62
    Thanks, I tried that and I guess ACAD 2005 doesn't have it, since nothing came up. I'll try the other method.
    Regards, Jim
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,115
    Quote Originally Posted by jim.dozorec
    Regards, Jim
    The Custimze User Interface was first introduced in 2006. It replaced the MN? style menus.
    2003-09
    Bergenfield, NJ
    697
    A friend of mine told me about this AUTOLISP option.
    The following is what he sent me.
    Another way for invoking edit dimtext is simple DDEDIT:
    (defun c:N ()(COMMAND "DDEDIT"));Text, MText, Attributes & Dims EDIT
    AutoLISP N command with space bar = almost the same speed as double click + less work for the hand holding the mouse. And as you can see it works with four groups of objects.
    2001-11
    62
    Thanks for the lisp. It works great.
    Regards, Jim
  1. Double-Click Action Items
    Last Post: 2012-05-09, 03:45 PM
  2. Replies: 9
    Last Post: 2011-08-06, 06:53 AM
  3. Double click action on AEC dimension
    By Yancka in forum ACA General
    Last Post: 2010-02-02, 01:39 PM
  4. Assign functions to double click
    By lawson in forum NavisWorks - Wish List
    Last Post: 2009-10-26, 10:17 AM
  5. Double Click Action
    By SRBalliet in forum AutoCAD Civil 3D - General
    Last Post: 2009-03-05, 02:28 PM
