Thread: Viz Render - where is it in AutoCAD 2007?
    2006-05
    12
    Default Viz Render - where is it in AutoCAD 2007?
    I keep reading in various places that Viz Render comes with Autocad 2007. I have ADT 2007, but the only place I can find any mention of it is the tiny icon in the lower left portion of the Drawing Status Bar that has a greyed out comment "Link to Viz Render..." What am I missing?
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: Viz Render - where is it in AutoCAD 2007?
    VIZ Render does not come with AutoCAD 2007, only ADT and ABS include that. For 2007 versions of ADT/ABS they turned off the option to install it by default and you and to perform a custom install and choose to install when setting them up. If you already have ADT/ABS installed then you can simply go to add/remove programs and modify your installation of them to include it.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    13,656
    Question Re: Viz Render - where is it in AutoCAD 2007?
    Quote Originally Posted by bosso
    Hi
    Or do you mean the new Render engine that was put into AutoCAD 2007 - Mental Ray.
    Below extract comes via the Autodesk web site "AutoCAD - Features in Depth: Visualize"
    Quote Originally Posted by Rendering
    AutoCAD 2007 incorporates the mental ray rendering engine, the very latest in rendering technology. This powerful techology, used in Autodesk 3ds Max software, has been incorporated into a new user interface focused on making accurate and realistic renderings quickly and easily. This technology includes the use of preset renderings, as well as slider control that allows easy trade-off of time versus rendering quality. The new rendering, materials, and lighting enhancements make highly accurate rendered images available to any AutoCAD user, enabling you to achieve effects that previously required additional applications.
    Have a good one, Mike
  1. 2007 render background
    By artisteroi in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-08-22, 03:07 PM
  2. 3D e o RENDER do 2007
    By Brogueira-CADptbr in forum 3ds Max - General
    Last Post: 2007-11-29, 06:47 AM
  3. ABS 2007 and VIZ Render
    By bbambu in forum AMEP General
    Last Post: 2006-10-24, 03:44 PM
  4. Using old Render commands in AutoCAD 2007
    By g_e_guidi in forum AutoCAD 3D (2007 and above)
    Last Post: 2006-08-31, 04:00 AM
  5. Revit 9 - - >Acad 2007 Render
    By captainbunsaver in forum Revit - Rendering
    Last Post: 2006-05-08, 03:06 PM
