Thread: Configure 3D Faces and Solids within AutoCAD for optimum performance
    2006-12
    4
    Default Configure 3D Faces and Solids within AutoCAD for optimum performance
    hello everyone,
    Sometimes when importing dwgs into 3d studio max 7 the models look very cool but after some improving renderings the faces of 3d objects apear strange, with dark areas and not rendering some textures very well . .
    I thought it was the scale (size of the model) and rescaling it in max resolved my issue a couple of times.
    Then i a "friend" told me the problem was that i needed to configure autocad before making the model so that the faces and solids where optimized but my "friend" didnt told me where to change and what to change. nice frind uhh.
    well does someone knows what he was talking about ? or and better way of improving solids so they dont give problems in max ?
    thx in advanced and sorry for my bad bad english.
    0,0,0 The Origin
    8,570
    Default Re: Configure 3D Faces and Solids within AutoCAD for optimum performance
    The dark areas will be because of faces that are facing the wrong way. For example, 3dfaces can act somewhat like a one-way mirror and a 3dface that has been mirrored now faces toward the inside of the model. They can be flipped or (easier) specify that you materials are double-sided.
    HTH
    2006-12
    4
    jaberwok, ok
    If i do an flip normals that will also do the trick but i will have an extra extra work.
    So the better solution is like you refer to do an double sided texture. ok i will give it a try right away. cya in 10 min +-
  1. 2014: Microstation Solids to Autocad Solids
    By boyerd492098 in forum AutoCAD General
    Last Post: 2014-05-28, 05:14 PM
  2. Autocad 3d solids generate faces when copied to another drawing
    By david.handsaker675899 in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-04-20, 03:27 AM
  3. Convert 3D Faces to Solids
    By Kirk Bricker in forum AutoLISP
    Last Post: 2006-12-07, 07:04 PM
  4. BIM, 3D Faces, Solids, AEC Objects and Material Definitions
    By phyllisr in forum Revit Architecture - General
    Last Post: 2005-11-23, 01:31 AM
  5. Convert 3D Faces to 3D Solids?
    By tsbykatherine60220 in forum AutoCAD 3D (2006 or below)
    Last Post: 2004-09-13, 02:37 PM
