Results 1 to 6 of 6
Thread: viewports limited to 3
    2003-12
    20
    Question viewports limited to 3
    Hi all,
    Hope your holiday were happy happy.
    Here's my situation. We're working on a very large sewer project with LDT 2004.
    There are over 45 tabs. Usually with our plan and profile setups, there's only 2 viewports to worry about, per tab.
    But, were trying to show some extra info on some of the pages, but when we create a third and fourth viewport one of the other turn off. It seems like we can only have 3 on at a time, per tab. I don't recall regular AutoCAD ever doing this, but this isn't regular cad, it's LDT 2004.
    Has anyone else had this happen? I would think there is a toggle mode to set to correct this, but I'm not having any luck finding one for this.
    Thanks for any help regarding this lil prob.
    Have a safe New Year!
    I could stop if I wanted to mom of 3's Avatar
    2004-07
    jUSt in the middle
    366
    Default Re: viewports limited to 3
    I've never had that happen on 2004, but I do know that on 2006 which we use now, there is an issue with clipped vports. are any of them clipped?
    2003-12
    20
    Quote Originally Posted by wrestlemom
    By clipped, you mean custom shaped viewports, right?
    A few of them are normal set viewports, but some are made from odd shapes.
    I tried this just using the regular setup with viewports, and still encountered this problem. Anything more then 3, and the last one created prior to the new one, turns off.
    It's really irking me!
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    the ADT/vanilla command to fix this is MAXACTVP - set it to a higher number, 16 to 32 should be fine depending on how many you use on a regular basis. i would guess LDT uses the same command.
    This aggression will not stand. Man.
    2004-07
    jUSt in the middle
    366
    Quote Originally Posted by dmortar
    Yep. We don't use them anymore, because of the fact we would end up with corrupt drawings, yet no one has had an answer yet to the issue. As for no more than 3, I'm really not sure - not heard of that before your post.
    I think I would try Chad's suggestion & see if that helps. I'm going to go see if it makes a difference, too!
    2003-12
    20
    Talking Re: viewports limited to 3
    Quote Originally Posted by Chad_C
    Yeah!
    That worked great!
    "vanilla" command, I would have never guessed!
    THANKS!
  1. Ductwork limited to 999mm
    By tuitvlugt in forum Revit MEP - General
    Last Post: 2010-10-06, 04:48 AM
  2. Drawing Arc with Limited Info
    By jodi_sherrell in forum AutoCAD General
    Last Post: 2010-09-15, 03:43 PM
  3. Limited Number of Viewports
    By meredithmcarriker in forum AutoCAD Civil 3D - General
    Last Post: 2010-01-15, 02:54 PM
  4. Cutting tool seem very limited
    By ray salmon in forum Revit Architecture - General
    Last Post: 2009-08-21, 08:46 PM
  5. Limited Colours
    By phil.107804 in forum AutoCAD LT - General
    Last Post: 2006-03-07, 10:30 PM
