Results 1 to 10 of 10
Thread: AutoCAD 2005 "Hotfix cannot be applied" when trying to apply 2005 OE Hotfix
    2006-08
    17
    Default AutoCAD 2005 "Hotfix cannot be applied" when trying to apply 2005 OE Hotfix
    Some of the ACAD 2005 users here are having this error when trying to install the 2005OEHotfix. Any ideas?
    2001-12
    St. Louis
    5,412
    Default Re: AutoCAD 2005 "Hotfix cannot be applied" when trying to apply 2005 OE Hotfix
    Quote Originally Posted by mattj.120434
    I'm having no hits on that... is that the 'exact' error message they're getting? (like you saw it or they sent you a screenshot.
    any information about whether these are network or standalone installs and their operating system might help, too.
    thank you
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2006-08
    17
    I've seen the message myself and took a screenshot of it as well (see attached image). We are all running standalone licenses and are all on Windows XP Pro SP2.
    2004-07
    Detroit Michigan
    2,508
    Good luck. I have had issues installing hot fixes from AutoDesk and after
    a few hours I usually give up.
    Did you have a prior version of AutoCad installed?
    2006-08
    17
    No prior versions installed. I reinstalled AutoCAD and it worked. I just hope I don't have to do it too often.
    2004-06
    2
    I'm having the same error message. I am using autoCAD 2006, (no previous versions installed). This particular drawing was from an outside source. Unfortunately I don't know what version the drawing was created in or saved down to...
    I have downloaded the OEhotfix for 2004, 2005, and 2006. The 2004 and 2005 said they didn't work. There was no error message for the 2006. However, the hotfix didn't work. I am still getting the "ARX_ERROR: eNotThatKindOfClass" message.
    Any ideas on how to fix it?
    13,656
    Question Re: AutoCAD 2005 "Hotfix cannot be applied" when trying to apply 2005 OE Hotfix
    Quote Originally Posted by lcalbery
    Hi
    Did you apply the following Hotfix...
    ID: DL7047371 - Hotfix - Autodesk 2006 OE
    Have a good one, Mike
    2004-06
    2
    Hi Mike,
    Yes that is the exact hotfix I applied. Could it be that my autocad was installed via download from another city (our head office)? If so, would IT from head office have to download the fix?
    Thanks!
    13,656
    Hi
    As far as I am aware, it should not matter... but I guess anything is possible.
    I wonder if the message "ARX_ERROR: eNotThatKindOfClass" could be appearing due to a *missing* Object Enabler...
    Does the drawing file in question contain Proxy Graphics / Objects from a Autodesk vertical product?
    2006-08
    17
    When the ARX_ERROR: eNotThatKindOfClass" appears here, I install the Hotfix as well as the Arch Desktop object enabler.
  1. Hotfix for text problem caused by Microsoft Hotfix KB918118
    By JD Mather in forum Inventor - General
    Last Post: 2007-03-01, 01:42 PM
  2. AutoCAD 2005 custom toolbar buttons show as "?"
    By jim.dozorec in forum AutoCAD Customization
    Last Post: 2006-07-18, 07:20 PM
  3. Script file makes AutoCAD LT 2005 "hang"
    By AutoTAD in forum AutoCAD Customization
    Last Post: 2006-01-18, 02:16 PM
