Results 1 to 7 of 7
Thread: Attribute Extraction from feature classification
    2005-05
    102
    Angry Attribute Extraction from feature classification
    I have few feature classification files that i have created. I am creating feature class for my conduits and pullboxes. I would like to extract the information from my feature classification into a table similar attribute extraction. Can this be done.
    Thanks
    13,654
    Default Re: Attribute Extraction from feature classification
    Hi
    Please explain exactly what you mean by...
    Extract the information from your feature classification
    Example - How is the information stored in the first place ( Attributes / Text / MText / etc ).
    Have a good one, Mike
    I could stop if I wanted to ekubaskie's Avatar
    2001-12
    Anchorage, Alaska
    324
    Quote Originally Posted by Mike.Perry
    Hi
    Mike, is feature classification available in vanilla AutoCAD? AFAIK it is a Map3D operation. Perhaps the question belongs in the Map forum.
    I had thought that info in the data grid could just be copied & pasted into a spreadsheet, but that doesn't seem to work in the current Map3D version.
    2005-05
    102
    Currently, i am using map3d 2007. By using feature classification, you can identify what each layer is used for example instead just being a line, it can be a conduit with some inteligence behind it. The intelligency can be stored as object data. We are trying to use this feature so we can do our quantity takeoff for cost estimation and enforce cad standards.
    thanks
    --Vahe
    Hi
    13,654
    Quote Originally Posted by VBOYAJI
    Hi Vahe
    Thank you
    Please note I have *moved* this thread from the AutoCAD 2007 General forum to this one...
    Why? - Feature Classification is not a function of vanilla AutoCAD.
    Thanks, Mike
    Forum Manager
    100 Club JeremiahM's Avatar
    Colorado Springs, CO
    186
    I have not used feature classes extensively, but i believe you can extract the data by attaching the drawing and doing a query. I would assume a Properties query because you can see Classes in tools like Quick Select.
    Jeremiah
    Jeremiah McKnelly, GISP
    www.spatialbiz.com
    Weapons of choice: Map 3D, AUD, AIMS and SQL!
    TN/KY Area
    1,640
    Quote Originally Posted by ekubaskie
    No copy and paste doesn't but the options to export does.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
  1. Extracting sdf layer and using feature classification
    By john.bendix in forum AutoCAD Map 3D - General
    Last Post: 2010-05-20, 11:38 PM
  2. FEATURE CLASSIFICATION
    By trconnet in forum AutoCAD Map 3D - General
    Last Post: 2008-07-16, 02:38 PM
  3. FEATURE CLASSIFICATION
    By VBOYAJI in forum AutoCAD Map 3D - General
    Last Post: 2005-07-11, 04:52 PM
