Thread: Naming PDF files when batch plotting
    2006-12
    35
    Default Naming PDF files when batch plotting
    Happy new year to all
    When printing your drawing set to PDF by checking your sheets views, is there an automated way to name the PDF files?
    i am currently naming the files sheet by sheet when prompted by Revit.
    Please advise
    Thanks - Mo
    I could stop if I wanted to whittendesigns's Avatar
    2004-07
    330
    Default Re: Naming PDF files when batch plotting
    I think that Revit has a problem when printing pdf's that you have to manually name every sheet. If I remember correctly, I think someone said that temporarily, you can print to dwf your full set, then print to pdf and you will be able to get all files into one pdf without all the hassle.
    Some small voice telling me also you maybe able to select print to dwf, select your sheets, and right before you print select the pdf and it might go.
    Search here and RevitCity, there's been a ton of pdf questions.
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    The only way I know of how to properly "batch plot" to pdf is through the Revit PDF Writer 4.2
    If you do a search you will see a few posts that include the exe file to run...you would most likely need to rename the file extension after you download it, since exe is not a file you can upload....I have uploaded one that is xex, which after you download it, you need to rename it...
    You know what, I know what to look for, I will look for it and post it after this post....
    Happy New Year
    2015-11
    Royal oak, Michigan
    1,513
    http://forums.augi.com/showthread.ph...ght=PDF+Writer enjoy
    I remembered slightly wrong...the name is pdfwriter.zip, but it isn't a zip file...just rename it to be pdfwriter.exe
    2006-12
    35
    THanks for your suggestions
    Mo
  1. Batch pdf's with automatic file naming.
    Last Post: 2011-11-24, 11:36 PM
  2. Batch plotting .plt files
    By thomasf in forum AutoCAD Plotting
    Last Post: 2007-05-16, 07:22 PM
  3. Batch Plotting DWG files containing multiple Layouts
    By sudhirkizhakoote in forum AutoCAD Plotting
    Last Post: 2007-03-15, 07:40 AM
  4. Batch Plotting PLT files with Sheet Set Manager
    By kwright.74399 in forum AutoCAD Plotting
    Last Post: 2005-09-21, 02:09 AM
  5. Batch Plotting: Across Multiple Files...
    By ronjon in forum Revit Architecture - Wish List
    Last Post: 2004-12-28, 07:30 PM
