Results 1 to 6 of 6
Thread: AutoCAD LT 2007 Saved in 2004 DWG format causes error - ARX_ERROR: eDuplicateKey
    Member momwolf70's Avatar
    2006-06
    5
    Default AutoCAD LT 2007 Saved in 2004 DWG format causes error - ARX_ERROR: eDuplicateKey
    I use AutoCAD LT 2007 and save into AutoCAD Lt 2004. When my co-worker that uses AutoCAD Lt 2006 tries to open a drawing it gives a "ARX_ERROR: eDuplicateKey" error. Can anyone please help or have any suguestions?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: AutoCAD LT 2007 Saved in 2004 DWG format causes error - ARX_ERROR: eDuplicateKey
    Quote Originally Posted by momwolf70
    I would have suggested an Object Enabler was missing for your 2004 version, but the Autodesk Object Enabler Selection Tool doesn't show any 2007 products.
    Does running the Audit command (or opening with Recover) in LT 2004 find any errors?
    If they resave in LT 2004 and reopen in LT2004 does the error persist?
    2002-01
    jUSt Here (a lot)
    9,100
    2006-06
    5
    Quote Originally Posted by Opie
    Thanks for the help. I got my co-worker to get the Object Enabler for his AutoCAD Lt 2006. So far it is doing the job.
    Thanks again for the help.
    2006-06
    Southern California
    3
    Smile Re: AutoCAD LT 2007 Saved in 2004 DWG format causes error - ARX_ERROR: eDuplicateKey
    Thanks Opie. The first link did the trick for us!
  1. AutoCAD 2007 and 2008 unable to open a DWG file saved in 2004 format
    By Neo_Richard_Blake in forum AutoCAD General
    Last Post: 2007-07-09, 08:50 PM
  2. Replies: 5
    Last Post: 2007-06-20, 01:22 AM
  3. Replies: 1
    Last Post: 2007-02-14, 04:07 AM
  4. ACAD 2007 saving down to ACAD 2004 - ARX Error: eDuplicateKey
    By Dicastaddict1 in forum AutoCAD General
    Last Post: 2006-10-26, 03:35 PM
  5. AutoCAD 2007 - SaveAs 2004 format.
    By b_v_mc in forum AutoCAD General
    Last Post: 2006-06-01, 05:08 PM
