Results 1 to 8 of 8
Thread: DWG file...not developed...by Autodesk error
    100 Club jrichardson's Avatar
    2005-07
    St. Paul/Minneapolis, MN
    143
    Default DWG file...not developed...by Autodesk error
    AutoCAD 2007 - Windows XP
    I am getting this dialog box when opening up one of the project files. this file is 1 of 300+ files and is the only one giving me this dialog. Any idea what is causing this? It happens on any machine we try it with. It happens with the drawing saved as 2004 or 2007. AutoCAD 2006 will display the "Drawing file is not valid." dialog box.
    We do use Revit Structure in house but this project is no where near Revit and the people working on it do not have Revit on their machine.
    Any ideas??
    thanks,
    jamie
    Earth
    9,803
    Default Re: DWG file...not developed...by Autodesk error
    Was the drawing last saved with a non-Autodesk product?
    That dialog has a lot to do with this lawsuit, and the countersuit
    See also: http://www.adskvoda.com/
    R.K. McSwain | CAD Panacea |
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by rkmcswain
    I figured as much. I have ignored the error message for the most part.
    I have noticed it popping up when coworkers are using different versions
    of Autodesk products. Annoys some of the lesser computer literates in my office.
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Is this base AutoCAD? Perhaps you should do a SAVEAS a MUCH earlier version? Purge it and try the saveas R14 option. This should clear out anything going on with the file and update it when opened again in 2007.
    This is a guess (untested) but seems logical it should clear out the "bad" data that causes the message. Just be sure to keep a backup version of this file in case saving it back so far causes it to lose any functionality.
    Earth
    9,803
    Quote Originally Posted by Dilbert
    That is a very good point that is often overlooked. I can't tell you how many times I have found people trying to "fix" a DWG file (or any file for that matter) and they forget to stash a copy of what they started with....
    2005-07
    143
    Thanks for the info. Interesting reading. We are still trying to figure out on our end what saved this file to activate this dialog. Acad2006 would not open the file because I had it saved as 2007. Bringing the file up in 2006 and saving it down than pulling it back into 2007 seemed to stop the dialog box.
    jamie
    I could stop if I wanted to Steve Johnson's Avatar
    2004-11
    Western Australia
    294
    I had a few things to say on this subject in Bug Watch November 2007 (written some time before the writs started flying!).
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    If I take a PDF and export it to DWG/DXF in Adobe Illustrator I get that error opening it in acad.
    So it's not always a bad thing...
  1. What Is being Developed for Revit Out There?
    By Kevin Janik in forum Revit - R & D Lounge
    Last Post: 2009-03-16, 11:08 PM
  2. Has anyone developed any courseware??
    By pauljordan in forum Revit MEP - General
    Last Post: 2008-10-22, 02:53 PM
  3. Developed Elevation
    By ck.107547 in forum Revit Structure - General
    Last Post: 2008-07-03, 08:09 PM
  4. Developed Radius of a Helix
    By cadkiller in forum AutoCAD General
    Last Post: 2007-12-10, 09:34 PM
  5. Developed Elevation
    By ck.107547 in forum Revit Structure - Wish List
    Last Post: 2006-06-01, 02:56 PM
