Results 1 to 7 of 7
Thread: After running igesout command from MDT I have to reset to my vanilla AutoCAD profile
    2004-07
    Detroit Michigan
    2,508
    Default After running igesout command from MDT I have to reset to my vanilla AutoCAD profile
    Everytime I run MDT to do an igesout, I have reselect the vanilla profile the next time
    I click on my shortcut to run AutoCAD.
    Is there a specific reason this happens?
    MDT is run from a separate shortcut than Vanilla.
    I do not that the Vanilla shortcut would open as MDT.
    Suggestions?
    150700
    3,439
    Default Re: After running igesout command from MDT I have to reset to my vanilla AutoCAD profile
    Quote Originally Posted by Robert.Hall
    Suggestions?
    You aren't calling a profile from the shortcut, are you, using the \p switch?
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by BrenBren
    No, but I probably should.
    I am guessing that would fix the problem.
    150700
    3,439
    Worth a try ~shrug~
    2004-07
    Detroit Michigan
    2,508
    I tried loading a profile using the shortcut but then I had to appload
    all of my lisp routines. Ouch! Is there something I need to do
    with the lisp files? I have them in the startup suite.
    150700
    3,439
    Are you pointing to the folder where the lisp files are in your support files?
    Did that make sense? Under files, support files, you have to show the folder where the lisp files are.
    2004-07
    Detroit Michigan
    2,508
    Yes, it points to the correct folder. I don't think I will ever figure out what
    AutoCAD is up to. I loaded it up the morning with the profile shortcut and
    was missing all but 2 of the toolbars. After resetting the profile, the missing
    toolbars appeared.
    No matter what I setup, I think the software has a mind of its own!
  1. Vanilla AutoCAD 2010 running from ACA icon
    By gregb in forum ACA General
    Last Post: 2009-06-07, 01:12 AM
  2. AutoCAD Electrical type Icon Menu in AutoCAD Vanilla !
    By iqbal.ahmad in forum AutoCAD General
    Last Post: 2009-04-15, 05:33 AM
  3. Load vanilla AutoCAD profile at startup
    By Cosmic Traveller in forum AutoCAD General
    Last Post: 2006-11-30, 09:42 PM
  4. Problem Running Excel From AutoCAD Shell Command
    By CADdancer in forum AutoLISP
    Last Post: 2006-02-10, 02:39 PM
  5. Replies: 3
    Last Post: 2006-01-17, 11:26 PM
