Results 1 to 10 of 12
Thread: Explode Text into outlines in AutoCAD LT
    2006-05
    7
    Red face Explode Text into outlines in AutoCAD LT
    Hi Everyone
    I am making stencil for sheet of metal- (letters have to be brushed ).
    Does anybody know how to explode text in AutoCAD so I can have outlines only?
    Thank you.
    Sonia
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Explode Text into outlines in AutoCAD LT
    You can use the Explode Text tool in the Express Tools Menu.
    Earth
    9,805
    Quote Originally Posted by sstadnyk2002
    Hi Everyone
    Thank you.
    Sonia
    If for some reason you don't have access to the Express Tools, you can use WMFOUT and WMFIN to do the same thing.
    R.K. McSwain | CAD Panacea |
    2003-10
    United Kingdom
    50
    Quote Originally Posted by rkmcswain
    how does this wmfout and wmfin do to explode text into outlines?
    Earth
    9,805
    Quote Originally Posted by vince.59412
    Do you mean "what it the procedure?" or "how does it do it?"
    If the former, run the WMFOT command, pick the text, give it a file name. Run the WMFIN command, pick the file, pick the UL of the viewport as the insertion point, then scale 2X.
    If the latter, it's because WMF format only supports vectors, so the "text" is converted to polylines and/or lines.
    2005-02
    46
    Try creating your text in word and then paste special into autocad. Its great for making some funky fonts and you can use the outline of the text.
    100 Club jgrande26's Avatar
    2001-10
    Down the rabbit hole
    196
    Won't the textfill system variable do what Sonia's looking for?
    From Help:
    Controls the filling of TrueType fonts while plotting and rendering.
    0 Displays text as outlines
    1 Displays text as filled images
    0,0,0 The Origin
    8,570
    Quote Originally Posted by jgrande26
    From Help:
    That will help with display of the text but won't give useable acad entities for manufacturing a template.
    All AUGI, all the time Avatart's Avatar
    2004-06
    Upsidedown in dreamtown
    928
    Also, if you have a copy of Adobe's Illustrator, you can make the text look exactly as you want it and then DXF it out to AutoCad.
    2006-05
    7
    I do not have access to Express Tools, and I don't have Adobe Illustrator but wmfout works!.
    Thank you very much for your help.
    Sonia
  1. Explode Mtext to Text
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2009-01-30, 04:06 PM
  2. Explode Text??
    By ty_demo15 in forum AutoCAD LT - General
    Last Post: 2008-03-12, 02:07 PM
  3. Explode text
    By pgastelum77763 in forum AutoCAD General
    Last Post: 2007-09-26, 11:02 PM
  4. Convert / Explode Text into geometry
    By lightnerbe in forum AutoCAD General
    Last Post: 2007-05-23, 04:47 AM
  5. Text Explode Problem
    By Shoey in forum AutoCAD General
    Last Post: 2005-10-05, 04:33 AM
