Results 1 to 9 of 9
Thread: This is not my camera....
    I could stop if I wanted to ronie_ernanto's Avatar
    2006-11
    Jauh di Sidoarjo sana (Indonesia)
    312
    Default This is not my camera....
    It's Samsung Digimax A503, 5 mega pixels, 5x digital zoom, 2" LCD. A cheap one. It's still unfinish drawing, Especially back side of camera and the lighting. Need comments and critics...
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: This is not my camera....
    I can't critic as I couldn't reproduce it.
    How did you get the lettering around the lens?
    Which software did you use to create it?
    How long did it take to render?
    2006-11
    312
    Quote Originally Posted by Opie
    Only A2007 I used to make rotating letter. Letters from text command, I choose the similar font type, type it, explode it with txtexp ( I know this command from somebody - I forgot who - here in AUGI.COM, thx guys...), edit some parts, region and union it again, extrude, and rotating it - one by one letter ( I want to make a wish list about rotating text - or are there another way to make it ?)
    About 15 min to render ( I use AMD Athlon 1.29 Ghz, 256 MB Ram,Excalibur Radeon 9000 Pro 64 Mb - very low spec, poor me!!!! ), it should be faster with better computer.
    You - and others - can reproduce it, believe me. Don't say you can't reproduce, the only one you need to draw is time.
    13,656
    Question Re: This is not my camera....
    Quote Originally Posted by ronie_ernanto
    <SNIP>
    Hi
    Have you looked at the Express Tools command ArcText, it may prove helpful / useful...
    Have a good one, Mike
    2006-11
    312
    Quote Originally Posted by Mike.Perry
    Hi
    You have CAD dictionary on your brain??? Looks like you always know everything about CAD. (but you still not answer my question about unretain material..hehehe) Thx.., that will help, but just now I try but when I double click to edit try to change the font, I can't found the the font type. And also I can't get when I try to explode with txtexp.
    2002-01
    jUSt Here (a lot)
    9,105
    The Arc Aligned Text is not a standard text or mtext object. You would first need to explode the Arc Aligned Text. This will create the individual text objects for each letter. You could then use the Explode Text Express Tool to explode the text objects.
    That's about as much as I can do in relation to that image. Still looks good.
    2006-11
    312
    After I explode the Arc Aligned Text, the font type is changed automatically to standard txt font, and I can't change it again to first font type. I don't want the text on the camera use a standard ACAD font. (or I'm still so stupid that don't know how to use Arc Aligned Text? )
    2002-01
    jUSt Here (a lot)
    9,105
    Have you created the appropriate text style with the desired font?
    2006-11
    312
    , Now I get it...thx
  1. Camera settings
    By Shizzjr in forum AutoCAD General
    Last Post: 2008-11-06, 06:04 PM
  2. Camera in MEP?
    By Beancud in forum Revit - Platform
    Last Post: 2008-04-08, 08:40 PM
  3. Caméra
    By dominique.berra in forum Revit Architecture - General
    Last Post: 2007-03-12, 11:17 AM
  4. show camera
    By Archman in forum Revit Architecture - Wish List
    Last Post: 2006-11-10, 10:22 PM
  5. camera add ons?
    By ggarness in forum AutoCAD General
    Last Post: 2004-08-26, 06:20 PM
