Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 2D plumbing fixture - behaves like 3D
  1. #11
    I could stop if I wanted to ita's Avatar
    2003-09
    Perth Australia
    365
    Default Re: 2D plumbing fixture - behaves like 3D
    Aaron, great tip. Thanks.
  2. #12
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,731
    Aaron, in your Santa Rosa file, you have detail components for plan & elevations.
    Inside each of those detail components do you have a detail component that is just a 'mask' (filled region)?
    Is there a way to force filled a filled region to the back in a detail component? My filled regions are always on top.
    I can see it's going to be a pain to have to create an additional detail component just for a 'mask'.
  3. #13
    2003-05
    Brisbane, Australia
    1,731
    Don't worry. I got it working.
    I was using a Region Fill that had a Solid pattern the was white in colour. I see the trick is to apply No Pattern to the Region Fill. I guess I was under the inpression that would still result in a see through family using No Pattern.
  4. #14
    2002-02
    St. Louis, MO
    4,695
    Yes. that is a little known trick that needs to be highlighted for those working with AutoCAD.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
  1. 2014: Plumbing Fixture Counts
    By kim579708 in forum Revit Architecture - General
    Last Post: 2015-04-17, 11:24 PM
  2. 2011: Plumbing Fixture
    By jamie santiago in forum Revit Architecture - General
    Last Post: 2011-09-29, 01:26 PM
  3. Plumbing Fixture
    By sjsl in forum Revit Architecture - General
    Last Post: 2008-04-10, 03:31 PM
  4. Plumbing Fixture
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2006-10-13, 01:04 PM
  5. Plumbing Fixture Schedule
    By CADMama in forum AMEP General
    Last Post: 2006-08-15, 05:24 AM
