I have an assembly consisting of an Ipart with a 1 to 4 row feature table driven array. The Ipart altering the width of the complete assembly.
In the assembly a part fits into the array that needs to be table driven & linked to the Ipart array.
The assembly part pattern, needs to also incorporate part suppression, so that a different part can be shown in some of the part feature pattern positions instead.
Can this be done & if so, could you give me an example of how?
Presumably this would have to be written in an external spreadsheet & linked to the assembly parameters.
Therefore can I save the Ipart spreadsheet & link it back to both the part & assembly & simply add columns titled with the Assembly occurrence names & controlled with a cell name of Suppress or Compute as necessary, as this would be the method for part feature suppression. Or would some other method be required. If you could refer me to any Autodesk training material, tutorial files, skills builders, or own files covering this area it would be appreciated.
