Hi
Is there any command to mirror xrefs keeping everything as it is ( ie without flipping dimension and text etc... )?
Shaji Thankachan
KEO
Hi
Shaji Thankachan
KEO
Unfortunately I don't think there is, currently the system variable 'mirrtext' controls whether text or dimensions flip when mirrored, however when the text or dimensions occur within blocks or xrefs then you cannot control whether the text or dimensions are flipped.Originally Posted by shajichunakkara
Another thing which may help, is that when text attributes occur within blocks, they are controlled by the mirrtext sysvar. Therefore if you have blocks containing text which you want to have mirrored versions it may be worthwhile to set your blocks up to contain attributes instead of mtext or dtext.
Hi
You may wish to browse the following thread...
Keep Text within xrefs readable when mirrored
Have a good one, Mike
