Results 1 to 9 of 9
Thread: How to I refer to a detail ?
    I could stop if I wanted to Maximillian's Avatar
    2006-09
    258
    Default How to I refer to a detail ?
    I Am still learning Revit. I have a drafting view of a detail. On the foundation plan i want to insert a bubble with the page and detail number. How is this handled in revit?
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: How to I refer to a detail ?
    When you create your callout or detail view check out the options bar, be sure the eference another view box is checked and select the appropriate drafting view. Then you simply drag and drop your drafting view onto a sheet view and the detail cross reference will update automatically
    2006-09
    258
    I currently have a "drafting view" where I manually drew a detail of a caisson. I am not even sure of where to get a bubble (doesn't show up in symbols) I am not using any current drawing to generate the detail like with a callout. Its kind of like "what came first the chicken or the egg"? The detail or the bubble?
    2015-12
    3,753
    I think I understand what you want to do.
    The detail is a separate drafting view, not drawn directly in the foundation plan sheet, right? If so, inserting the drafting view onto your foundation plan sheet will result in a title and reference bubble.
    If you haven't drawn it as a separate view then copy all the detail linework to a drafting view at then drop that view onto the foundation plan sheet.
    2006-09
    258
    Just when I start to feel like I mastered revit, new concepts open up.
    See attached example.
    Thanks for the help!
    2015-12
    3,753
    See the attached video. Hopefully the size is OK for you
    Keep in mind that you can create your drafting view first (as shown in the video) or, when creating your referenced view, you can create a new draftign view and then draw it later.
    HTH
    2001-12
    Irvine, CA
    7,567
    After you have created your 2D drafting in a drafting view
    Open the view you want to refer to the detail in
    Select View menu > New > Section: Detail
    Options Bar > Check box: Refer to Other View
    Sketch the section/detail
    Toggle off the tail if you don't want it.
    (see attached image)
    I posted this because I couldn't view Dimitri's video.
    2015-12
    3,753
    Thanks Steve. Out of curiosity what was the problem with the video?
    2006-09
    258
    Video says" encountered error"
    Thanks to everyone for the help. I will give a try.
    edit:
    yes! IT WORKED
  1. 2013: refer to linked view - dimension+ text orientation
    By cr_gixxer in forum Revit Architecture - General
    Last Post: 2014-07-08, 05:01 AM
  2. Does a drawing refer to an XREF
    Last Post: 2006-11-01, 09:05 PM
  3. Need help finding this font (refer to image)
    By ajtrahan in forum CAD Management - General
    Last Post: 2006-10-23, 08:46 PM
  4. Notes that refer to drawing number on sheet
    By Archman in forum Revit Architecture - General
    Last Post: 2005-07-30, 12:46 AM
  5. Labels that Refer to Nothing
    By bowlingbrad in forum Revit Architecture - Wish List
    Last Post: 2004-12-09, 02:15 AM
