Results 1 to 6 of 6
Thread: Mystery Error
    2004-07
    2
    Default Mystery Error
    Has anyone ever heard of this error "error: bad argument type: stringp nil"
    it doesnt seem to be causing any problems in AutoCAD, but I get this ever with ever drawing I open up.
    If you have ever heard of it, and know how to get rid of it....please let me know....our CAD guys are stumped..
    thanks alot
    D.Jack!
    150700
    3,439
    Default Re: Mystery Error
    This is from a KB article
    This error occurs when the Start in folder for the shortcut that starts AutoCAD is a Universal Naming Convention location (UNC path) on the network. The following example shows UNC paths used in the shortcut properties:
    Target = \\bilbo\apps\acad\acad.exe /c c:\acad2000
    Start in = \\bilbo\apps\acad
    One solution to this problem is to map a drive to the AutoCAD folder, and then change the Start in folder to the mapped drive.
    To map a drive in Microsoft® Windows®:
    1. In Windows Explorer, click Network Neighborhood and browse to and select the AutoCAD folder on the network drive.
    2. Right-click the AutoCAD folder and choose Map Network Drive from the shortcut menu.
    3. Assign an unused drive letter (For example, T), and then choose OK.
    To change the Start in folder for the shortcut that starts AutoCAD:
    1. On the Windows desktop, right-click the icon for the shortcut that starts AutoCAD and choose Properties from the shortcut menu.
    2. On the Shortcut tab, change the Start in location to use the mapped network drive. In the following example, T is the drive that was mapped from the AutoCAD folder on the network: Start in = T:\
    3. Choose OK.
    You should now be able to start AutoCAD without encountering the error.
    2015-12
    Arizona
    2,478
    You have something in your start-up that loads
    some old piece of LISP programming that is not happy.
    http://usa.autodesk.com/adsk/servlet...linkID=2475323
    2001-05
    Austin, TX USA
    2,201
    It looks like you have a lisp routine that is loading and it has an error in it some where. You'll need to remove each routine one by one and restart AutoCAD tell you don't get that message. Which ever was the last routine you removed will be the one with the error.
    Then when you find the one with the problem, you can post it in the lisp forum to see if anyone can figure out the error.
    2004-07
    2
    I really hope this works.....thanks alot for your quick response!!!
    150700
    3,439
    Let us know if it works.
  1. mystery gird
    By cbaze in forum Revit Architecture - General
    Last Post: 2015-03-04, 07:35 AM
  2. ADT 2005 Mystery???
    By troberts.123206 in forum ACA General
    Last Post: 2006-10-31, 11:37 PM
  3. VLX Mystery
    By lance.81922 in forum AutoLISP
    Last Post: 2005-03-18, 04:45 PM
