Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 74
Thread: AutoCAD Speak
    5
    Default AutoCAD Speak
    This thread was started on TheSwamp, http://www.theswamp.org/index.php?topic=14549.0, and you guys might have fun with it also.
    (defun c:SayIt (/ Phrase$ Sapi)
      (if (setq Phrase$ (getstring "\nEnter phrase: " t))
        (progn
          (setq Sapi (vlax-create-object "Sapi.SpVoice"))
          (vlax-invoke Sapi "Speak" Phrase$ 0)
          (vlax-release-object Sapi)
        );progn
      );if
      (princ)
    );defun c:SayIt
    Last edited by Terry Cadd; 2007-01-19 at 04:26 AM. Reason: Needed to add Sapi as local variable
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Default Re: AutoCAD Speak
    ok that is cool.
    I've got a VBA that will play WAV files, but nothing like this.
    100 Club jpduhon's Avatar
    2005-10
    153
    jumpin' Jesus, i'm gonna have fun with this one!!!
    thanks.
    1,054
    Quote Originally Posted by jpduhon
    thanks.
    Let's see.
    add a phrase to when an alert is issued. so you have a dialog and verbal.
    add to customer commands just for fun. ("now running..." "input data now" "program complete")
    has to be someway to make it speak commands after they are entered.
    mess with unsuspecting users at time intervals or on specific commands.
    Turlock, CA
    6,419
    Quote Originally Posted by madcadder
    Just rearrange it to be a function with an argument.
    (defun SayIt (Phrase$/ )
      (if (setq Phrase$)
        (progn
          (setq sapi (vlax-create-object "Sapi.SpVoice"))
          (vlax-invoke sapi "Speak" Phrase$ 0)
          (vlax-release-object sapi)
        );progn
      );if
      (princ)
    );defun c:SayIt
    Now you could call it without user intervention, e.g. in the begincommand event:
    (sayit commandname)
    C:> ED WORKING....
    LinkedIn
    1,054
    Quote Originally Posted by Ed Jobe
      (if (setq Phrase$)
        (progn
        );progn
      );if
      (princ)
    );defun c:SayIt
    (sayit commandname)
    Just a little more instruction if you would. You make it sound like I can load the routine and when a command is typed and executed it would speak the command.
    What I see (scary) is this would work with another lisp and I could make it speak the custom command.
    Turlock, CA
    6,419
    Sorry, I assumed you had a lisp or vba background. In lisp you would place the code in a reactor and "commandname" would be returned from monitoring the current command sysvar (CMDNAMES). In vba, "commandname" is passed via the BeginCommand event.
    C:> ED WORKING....
    LinkedIn
    I could stop if I wanted to sschwartz85916's Avatar
    2005-04
    Oakland County, Michigan
    424
    Talking Re: AutoCAD Speak
    Quote Originally Posted by Terry Cadd
    (defun c:SayIt (/ Phrase$)
        (progn
        );progn
      );if
      (princ)
    );defun c:SayIt
    Oh, this is some seriously good stuff.
    Here's a shorter version. Also found that certain characters can be used as a slight pause, such as periods and commas.
    (SayIt "What you, talkin about. Willis?")
    (SayIt "Houston, we have a problem!");<-- great for an *error* function...
    (defun SayIt (Phrase$ / Sapi)
      (princ)
    );defun SayIt
    2004-07
    Detroit Michigan
    2,508
    Sow do I make this say, "Good day to you sir, today we are going to conquer the world!"
    when I first open AutoCad?
  1. Replies: 0
    Last Post: 2015-08-07, 04:03 PM
  2. Speak 4 cad
    By maa in forum Software
    Last Post: 2006-06-30, 12:13 PM
  3. speak to autocad
    By jaberwok in forum Software
    Last Post: 2005-11-09, 08:12 PM
