Add Terry's last post to your ACAD.LSP file. Then add the following at the end or at least after Terry's code.Originally Posted by Robert.Hall
Code:(SayIt "Good day to you sir, today we are going to conquer the world!")
You can change the voice in Control Panel under Speech, also...
Does anyone know if you can download and install other voices?
I cud not resists doing this…
Copy and paste the first code into AutoCADs command window
Command: _
Now draw lines, arcs, circles . . . in AutoCAD, and hear what you are going to do. . .Code:(vl-load-com) (setq Command_Start_Reactor (vlr-editor-reactor nil '((:vlr-commandWillStart . Command_Start_Function ))) ) (defun Command_Start_Function (ObjReactor Command-In / ) (vlax-invoke (vlax-create-object "Sapi.SpVoice" ) "Speak" (car Command-In ) 0 ) (vlax-release-object (vlax-create-object "Sapi.SpVoice" ) ) )
To remove the voice, copy and paste next code into AutoCADs command window
Command:_
: ) Happy Computing !Code:(vlr-remove Command_Start_Reactor ) (setq Command_Start_Function nil Command_Start_Reactor nil )
kennet
I think we should implement at network wide distribution of this routine so that every time someone starts autocad the computer responds by saying:
"good morning Hal"
Peter
I found the MS Mike and MS Mary for download with a Google search but I think that if you want additional voices you need to purchase a seperate speech driver first.Originally Posted by timcreary
Did that right after Ed's post. No one has found it yet.Originally Posted by peter
"You've enjoyed all the power you've been given, haven't you? I wonder how you'd take to working in a pocket calculator."
10 points if you can name the movie without looking it up.
Wow dude that is awsome!
I had to use Microsoft Agent for one of my apps.
I wounder if there is any speech recognition built in so one could converse with autocad.
Thanks, Ed.Originally Posted by Ed Jobe
I'll check it out in a bit.
Hi Terry,
I just test your code,but my cad only silence,what wrong?
Originally Posted by Terry Cadd
