Page 3 of 8 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 74
Thread: AutoCAD Speak
  1. #21
    100 Club jpduhon's Avatar
    2005-10
    153
    Default Re: AutoCAD Speak
    Quote Originally Posted by Adesu
    Hi Terry,
    I just test your code,but my cad only silence,what wrong?
    first check the obvious non-cad things.
    1 are your speakers plugged in and turned on?
    2 make sure your speakers are plugged into the correct jack.
    3 make sure your system volume is not muted and the master volume and wave are turned up
    after you are sure these things are correct you move onto cad if there is still no sound.
    I've seen some of the smartest people miss the simplest things.
  2. #22
    2006-04
    466
    Now I'm thinking of shelling Microsoft Agent and using your program for each and every prompt!(etc.)
  3. #23
    2003-11
    277
    Thumbs up Re: AutoCAD Speak
    Hi jpduhon,
    Good info !!!
    Thanks for your tip,it's very clear,I would test again,thanks a lot.
    Quote Originally Posted by jpduhon
  4. #24
    All AUGI, all the time SRBalliet's Avatar
    2004-06
    Near Christiansburg, VA Looking for a closer job!
    500
    When I do it:
    Command: (setq Command_Start_Reactor (vlr-editor-reactor nil
    '((:vlr-commandWillStart . Command_Start_Function ))) )
    #<VLR-Editor-Reactor>
    Command: (defun Command_Start_Function (ObjReactor Command-In / )
    (_> (vlax-invoke (vlax-create-object "Sapi.SpVoice" ) "Speak" (car Command-In
    ) 0 )
    (_> (vlax-release-object (vlax-create-object "Sapi.SpVoice" ) )
    (_> )*Cancel*
    ; error: Function cancelled
    Command:
    Command: _line ; error: no function definition: COMMAND_START_FUNCTION
    Specify first point:
    Specify next point or [Undo]:
    I get that error message. I'm using LDD 2005. Is it a higher version thing?
  5. #25
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Quote Originally Posted by srb
    When I do it: . .
    Did you include the (vl-load-com) line ?
    : ) Happy Computing !
    kennet
    PHP Code:
    Command:
    ) 0 )
    (_> )
    Command:
  6. #26
    2004-06
    500
    Quote Originally Posted by kennet.sjoberg
    kennet
    PHP Code:
    Command:
    ) 0 )
    (_> )
    Command:
    Yes, sorry I missed that on my copy and paste, but it was there. Any other idea?
  7. #27
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    when copying and pasting to a command window the string has to be one long continuous string. any spaces are interpreted as an ENTER.
    to me it's easier to cut-n-paste into VLIDE and load from there. Plus you have the opportunity to save to file if you want to keep it.
  8. #28
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Hi Terry,
    I couldn't get it to work either and found online that SAPI 5.1 is built into Windows XP and Windows Server 2003. We're using MAP 3D 2007 on Windows 2000 here which has SAPI 5.0.2602.00. Yes, my speakers work for everything else including the "Preview Voice" button in "Speech in Control Panel". Did anyone get this to work on Windows 2000?
    Command: (setq Sapi (vlax-create-object "Sapi.SpVoice"))
    nil
    Command: (vlax-invoke sapi "Speak" "Do you want autocad speak ?" 0)
    ; error: bad argument type: VLA-OBJECT nil
  9. #29
    2004-07
    Detroit Michigan
    2,508
    The voice that is played isn't very loud on my speakers.
    I had to turn the volume up.
    Makes for some good office fun.
  10. #30
    2004-06
    500
    Quote Originally Posted by Tom Beauford
    I am using Win2000 and couldn't get it to work (see my posts below).
  1. Replies: 0
    Last Post: 2015-08-07, 04:03 PM
  2. Speak 4 cad
    By maa in forum Software
    Last Post: 2006-06-30, 12:13 PM
  3. speak to autocad
    By jaberwok in forum Software
    Last Post: 2005-11-09, 08:12 PM
