Results 1 to 9 of 9
Thread: How to bring in a Slide Library into AutoCAD 2006
    2005-12
    24
    Default How to bring in a Slide Library into AutoCAD 2006
    Once I create a slide library, how do I read it into AutoCAD 2006?
    Lance
    Super Moderator rkmcswain's Avatar
    Earth
    9,720
    Default Re: How to bring in a Slide Library into AutoCAD 2006
    To display a slide in a slide library (.slb extension), set FILEDIA to 0, enter ._VSLIDE and then specify the slide library file name followed by the slide file name enclosed in parentheses: slidelibrary(slide).
    ...or did you mean something else?
    R.K. McSwain | CAD Panacea |
    2005-12
    24
    rkmcswain,
    Where is the FILDEDIA located? Where do I enter _VSLIDE?
    Lance
    2001-08
    On the other side of the pond, where they speak real English!
    40
    As I understand it, both are entered at the command line.
    Cairo - no, not Illinois
    4,772
    Remember to set FILEDIA back to 1 afterwards, otherwise you're going to be wondering where your dialog boxes went when you try to open a faile in CAD later on....
    2015-08
    263
    Lance,
    If you want a slide show, you can use a script file. The "Delay" command will give you a delay in milliseconds. The "Rscript" command will allow you to repeat the script until the user hits ESC key.
    Regards,
    Abdul Huck
    2005-07
    2,356
    Also when you are compiling your slide library, don't delete the individual slides as there is no way to edit the library once it has been created.
    There is quite a bit of info in the Acad help files which might might be worth a browse.
    Earth
    9,720
    Quote Originally Posted by Steve.Sanderson(UK)
    Not true. There are a few tools out there that can do this.
    My favorite: http://www.dotsoft.com/slideman.htm
    2005-07
    2,356
    Quote Originally Posted by rkmcswain
    Wish I had know about that two months ago.
    Thanks for the link.
  1. 2012: AutoCAD Slide Library
    By rbhazie in forum AutoCAD General
    Last Post: 2015-12-07, 08:58 PM
  2. Replies: 1
    Last Post: 2007-03-10, 02:00 AM
  3. Replies: 3
    Last Post: 2007-02-15, 09:36 AM
  4. Replies: 2
    Last Post: 2006-10-06, 02:32 AM
  5. Replies: 5
    Last Post: 2006-06-15, 07:08 AM
