jmedley
I have done a search and cannot find anything on this error code or anything close. I have contacted Autodesk and their only fix to date is to reinstall ACAD. I had already formatted my drive and reinstalled everything on the entire machine, but the problem does not go away. It also happens to another machine on my home network.
When I try to use "file" from the menu bar Autocad crashes with the following error message.
FATAL ERROR: Unhandled e06d7363h Exception at 7c812a5bh. OK........When I hit OK it is gone. Everything! When I restart Autocad it ask me to restore the drawing. Doesn't do a bit of good. I end up right back where I started. I have the same results on numerous different files from my drawing directories.
I sure would appreciate any help you guys can give. I have already lost this week from Tuesday on............Man I haven't worked this hard in a number of years. Especially since I have accomplished nothing!
