Results 1 to 6 of 6
Thread: Drawing Conversion Tool from Autodesk
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Exclamation Drawing Conversion Tool from Autodesk
    If you get an "invalid file" error when trying to download a posted dwg file, please download and use the free drawing conversion tool by autodesk before requesting that the file sharer repost in "your" acad compatible version. I grumbled at first about this error myself, but find it is a LOT faster using this tool than it is to wait for the possible re-posting of a compatible file.
    DWG TrueView
    Use this FREE* download to accurately view, plot, and publish authentic DWG and DWF files. And now, DWG TrueView incorporates all the functionality of DWG TrueConvert. This means you can translate any AutoCAD or AutoCAD-based drawing file for compatibility with AutoCAD Release 14 through AutoCAD 2009.
    How it is used: Start the Trueview program, add files you need converted (as many as needed), and convert as required. once done, open (converted) files in your version of autocad.
    reminder: Dynamic Blocks are not compatible with Acad versions older than 2006. Thank you.
    S&D DB Sharing Forum
    2005-05
    9
    Default Re: Drawing Conversion Tool from Autodesk
    Is there no a tool that one could use on a folder with sub folders that have dwg files?
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by rakesh View Post
    you have to manually add the specific files you want converted. it is nice in that it lets you select a lot of files at once, and even save the list for future use. i'm assuming one use of this is when one continually send files to another office that is behind and the machines are not set to save back versions as a matter of default.
    2006-06
    South Bend, IN
    16
    I downloaded this program and unzipped it during the "run" process but can't find how to open the program. What have I done wrong? It doesn't show up under the AutoDesk programs on the start menu or did it put a short cut on my desk top. Help please.
    Just realized when I installed the program it said installation failed. Don't know why.
    Just found out my computer is a 32 bit. Is the program you download only 64 bit? How do I get it to work on a 32 bit computer?
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by jhanby View Post
    i'd copy the program to your hard drive first, then run. it should be 32 bit (?) cuz it works on mine, which is XP.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    You may need administrative rights to install it.
  1. REVIT VIEWER/CONVERSION TOOL
    By jjr339275 in forum Software
    Last Post: 2014-10-09, 06:09 PM
  2. Problem in CAD drawing conversion
    By bryan.fuller in forum Training
    Last Post: 2010-05-27, 04:40 PM
  3. Drawing Conversion Tool from Autodesk
    By Chris.N in forum Dynamic Blocks - Technical
    Last Post: 2007-10-02, 03:57 PM
  4. Looking for a Tif conversion tool
    By robert.1.hall72202 in forum Software
    Last Post: 2007-07-27, 12:37 PM
  5. 3D to 2D conversion tool
    Last Post: 2006-03-11, 03:43 AM
