Thread: Linking a Word document into AutoCAD 2007 DWG file
    2006-02
    Croswell, Michigan
    80
    Question Linking a Word document into AutoCAD 2007 DWG file
    Hello To All,
    I'm having trouble linking a word document. Usually I just copy to the clipboard and then paste special, check the link box and thats it. This doesn't seem to work properly in 2007.
    The insert OLE object works but it gives me the entire document. I only need to see certain parts of documents and they need to be linked so they update when a change occurs.
    William.Biskey
    2006-02
    Croswell, Michigan
    80
    Default Re: Linking a Word document into AutoCAD 2007 DWG file
    Edit, Paste Special is the answer to this. For whatever reason this will not work in one specific drawing that I was testing it in.
    Thanks
    William.Biskey
  1. linking a word document to a sheet or view
    By ntnik in forum Revit Architecture - General
    Last Post: 2008-10-10, 02:20 PM
  2. word document in revit9.1
    By rcerezo in forum Revit Architecture - General
    Last Post: 2007-02-06, 10:02 PM
  3. AutoCAD 2007 LT - import DWG into Microsoft Office Word 2003
    By sstadnyk2002 in forum AutoCAD LT - General
    Last Post: 2007-01-30, 10:40 AM
  4. Using a DWG in a Microsoft Word document
    By drafting_specialist96337 in forum AutoCAD General
    Last Post: 2006-08-25, 12:16 AM
  5. Import a Word document
    By amasella in forum AutoCAD General
    Last Post: 2006-03-07, 05:07 PM
